I have nearly completed a Brooks grinder and purchased an AbTec CBN
taper cup wheel, as seen here:
I set the metal section of the wheel to run true within about a half
thou, then measured the outside of the CBN composite rim as +/- 5 thou
runout. This runout causes some vibration and a sort of whirring noise
from the motor/spindle area. I tried touching the outside of the CBN
with a diamond point - this polished the diamond nicely but did little
for the wheel
So, I looked around on the net and found that diamond points are not
recommended for truing CBN wheels, see:
They recommend coolant and a metal bonded diamond nib -- which
apparently differs from a cluster diamond. Or alternatively, a
carbide wheel in a brake fixture.
I have neither of the recommended tools so was wondering what others
have done to true CBN composite wheels in the home shop. Are diamond
nibs available? Are plans available for a brake fixture for wheel
truing? (Norton has a brake fixture but it costs much more than my grinder... ( http://www.drillspot.com/products/34..._Truing_Device ) Or is there a different way of truing CBN wheels?
I also found a reference to truing with a mild steel block, but haven't found more info on how to do this? See: http://www.diamondedge.co.nz/shop/Su...nd+Truing.html
Also, I didn't expect to be using coolant with this grinder; any
thoughts on how to handle this aspect of truing CBN?
Not being able to true the CBN wheel has been a show stopper; any help or ideas would be appreciated.
John
for the wheel
John
