HSMers and gunsmiths often have to make do with equipment that's not perfect for the job, but it's what's available when the job needs doing. Today I started construction of my new shop in the garage, putting down footers for the walls. I very quickly found that the concrete nails wouldn't penetrate the floor that's harder than a mother-in-law's heart, and I couldn't find a proper sized carbide tipped drill in town. I did have a 5/16" drill bit for the hammer drill, so I drove the concrete nails into the wood to mark the floor, then drilled with the 5/16" bit. Being a cast bullet shooter, I used .30 caliber bullets that measure about .311", stuffed one in each hole, and drove the nails into the lead alloy. Those 2x4's aren't going anywhere!
David
Montezuma, IA
David
Montezuma, IA
