Lots of ways to keep the parallels apart in the vise. I was using some big "O" rings but they didn't seem to last all that long before they got weak. Plus they didn't work great on the taller ones as they only contact the bottom.
The other day I remembered I had a huge bucket full of clutch (and other) coil springs from snowmobiles.
A couple minutes to sort them out and I had a handfull of springs to use as seperators. They work great. You can put two end to end on each side if need be.
You can twist one inside the other if you need a certain length.
Unlike the "O" rings...you can use air to blow out the bottom of the vise and the springs don't blow away.
I'm sold
(er is that old ? )
Russ
I'm sold
Russ
