Does anyone know of a source for case hardened shaft in "nominal" sizes? I need a 5 - 6" section.
I want to install needle thrust bearings in the carriage handwheel on my Clausing lathe. I've purchased some drawn-cup needle bearings, and they need to run on a hardened shaft, but I need to be able to tap or thread the end for the handwheel screw.
I bought 1/2" Thomson linear shaft, which is case-hardened, and my strategy was to tap the center (which is soft) to attach the handwheel.
Unfortunately, Thomson shaft is spec'ed as -0.0005 - -0.001", so it's undersized for needle bearings.
Another possibility would be a drill blank, but I think those are through-hardened?
Any ideas?
Any ideas?
