Estate Sale Find
  • Estate Sale Find
    <P>Anyone know what this is?</P>
    <P>I bought it the last day of the sale for $1.50.</P>
    <P>If nothing else, I can use it for beating on.<IMG class=inlineimg title=Confused alt="" src="images/smilies/confused.gif" border=0 smilieid="10"></P>
    <P>&nbsp;</P>
    <P><A href="http://i267.photobucket.com/albums/ii319/ligito/P3120004.jpg">http://i267.photobucket.com/albums/ii319/ligito/P3120004.jpg</A></P>
    <P>&nbsp;</P>
    <P><A href="http://i267.photobucket.com/albums/ii319/ligito/P3120003.jpg">http://i267.photobucket.com/albums/ii319/ligito/P3120003.jpg</A></P>
    <P>&nbsp;</P>
    <P><A href="http://i267.photobucket.com/albums/ii319/ligito/P3120002.jpg">http://i267.photobucket.com/albums/ii319/ligito/P3120002.jpg</A></P>
    <P>&nbsp;</P>
    <P><A </A></P>
    <P>&nbsp;</P>
    <P><A </A></P>
    <P>&nbsp;</P>
    <P><A </A></P>
    See if that fixes the photos so we can see... I guess not.
      Closer?
      http://i267.photobucket.com/albums/i...o/P3120004.jpg
      http://i267.photobucket.com/albums/i...o/P3120003.jpg
      http://i267.photobucket.com/albums/i...o/P3120002.jpg
      Here it is.
      There were 6 pics but they were three duplicates, so I reduced the image count to three.
      It looks like and end-cap that is fitted to the end flange on/for a pipe or valve.
        Wheel Weight...? Toe jammer/masher...?
          I agree. That is a blind pipe flange for terminating the end of a pipe run that has been abandoned for some reason. Could also be used as a clean-out flange where excessive sediment is expected. It is not hardened, but it would make a good beater block for your workbench.
          There is no shortage of experts, the trick is knowing which one to listen to!
            Scrap.......................?
            Just got my head together
            now my body's falling apart
              Boy hole cover? As opposed to a man type hole cover?
              Tinkerer, good to see you still around. Don't be such a stranger.
                eh..... imagination required........
                large gear blank. Several small gear blanks cleverly disguised as one big one.
                Flywheel blank
                That's just the ones that came up first from it being round...... generic term "raw material".
                Obviously depends on material type. Steel vs CI is a start. Most of such should be steel, but a CI one is possible.
                  It does look like the old style stainer covers that we had on the swimming pools in the high schools, pre and right after WWII vintage pumps. Or as been stated a flange blank. And for the last day of a sale ya payed to much. shred is going for .06 cents a pound
                  Glen
                    OK, build yerself a small coke forge, heat and beat the sh1t out of it til the shape pleases you.
                    Lamp base maybe?
                      Looks like a land mine, use a soft hammer for beating on it.
                      Hal
                        Definitely not a standard pipe flange, holes are WAY too small and not near enough to the edge. Don't know what it is tho.
                          I used to do aluminum flanges for a foundry that were used on swimming pools. They started out looking like that less the bolt holes.
                          That was a good paying job that disappeared. I finally scraped out the fixtures for them.
                            Wow, you got scrap, I hope you didn't pay more than $100.00 a ton.
                              I cant see that as a gloat in any way an estate find wow I'd say junk but there you are have fun with your precious. find Alistair
