So I upgraded the processor in my mac mini from a core duo 1.66ghz to a Core2Duo 2.0ghz. Nice speed boost. Only problem is cooling. At full load the processor core gets to about 90 to 95 degrees C. The CPU is rated to ran up to 100C with throttling at 105C (Laptop class processor. Exposed die.) I would rather it be a little cooler. Once its starts warming up and the ambient goes up I am a little worried.
The heatsink has its own temp sensor on it and at 90C die temp the heat sink is only 60C. Not real good thermal transfer go on here. I tried a couple different heat sink compounds and no good. I milled the anodizing off the back of the heatsink flat and polished and that really didnt help either.
So my next idea is to use a low profile solid copper heatsink from something like a 1U server. Only problem is the size. I need to cut it down and drill holes for mounts. Any ideas on cutting it down without tearing up the fins? I was thinking about one of the low melting point alloys. Fill the fins and then mill, drill, and counterbore.
Will the alloy wet the copper? Maybe another idea?
