Home Made EDM
  • Home Made EDM
    Has anybody built their own tap/drill disentagrator from the articals in HSM, Flemings book, or ? I would like to build one. Any coments and/or ideas. Thanks - Blake
    The only ones that were home made I read about was at metalillness.
    The sinker edm
    http://bbssystem.com/viewtopic.php?t=501
    And the wire edm.
    http://bbssystem.com/viewtopic.php?t=73
    there is not tons of info but some good pictures.
      I did the Ben Fleming unit..
      I love it . Works as expected and is really handy
      Built it for under 100 bucks
      Rich
      Green Bay, WI
        You Mean something like this?
        This is the next step. A home built wire EDM
        Outback
        So much to learn, so little time
          Outback
          Speak of the devil and up he jumps.
            I have also built the Metal Disintegrater by Ben Flemming.
            http://cgi.ebay.com/BUILD-A-METAL-DI...QQcmdZViewItem
            I built if for a specific job of removing a broken EZ-out and bolt from an engine block. It worked well and the block was saved. The customer payed for all the materials to build it plus payed to remove the bolt so it just cost me a little labor. It was very simple to build.
            Mark Hockett
              No, Like this..
              Servo drive unit.
              burning a 3/16 square hole in a carbide insert as a test.
              About 35 minutes .140 deep.
              Used Kerosene.. EDM Fluid is 2-3 times faster
              I broke a stud in a 0-80 die ...
              The electrode is .032 brass shown here with fluid drained out
              The simple, yet very effective Ben Fleming Control.
              Rich
              Green Bay, WI
                LOL! I was reading Mikes links...thought that was pretty cool, sorta like another I'd seen.
                Then I see it was Jims rig... I just like that thing.
                  What type of power requirements are needed for something like these small sinker or tap burner EDMs?
                  Russ
                  Master Floor Sweeper
                    Pop Mechanics version
                    I vaguely remember an article in Popular Science or Popular Mechanics (1950's or 1960's) that had a plan for a simple - crude - version of this. Used a couple of light bulbs (those old Edison style thingies that were the only game in town back then). Don't have the details; tried it out and it worked!
                      In my former life I designed electrodes for machining aluminum die casting dies. Great engineering, loved that job.
