CNC: Tubular bells with no tubes
  • #31
    Hmm, seems unlikely we can discuss this with Einstein or Hawking.
    Just got my head together
    now my body's falling apart
    • #32
      I finally made a recording. The wow effect is because the chimes were swinging in front of the mic.
      <1 meg, 1 minute, mp3
      http://www3.telus.net/metalshopborealis/chimes.mp3
      • #33
        That sounds pretty cool.. I like how you can here the "tuning fork" sound for some time after the hit.. JR
        • #34
          Thanks for the recording Evan. It really rings well. But if I could make just one suggestion, change the tuning. There are two notes there, that when heard together, cause them both to sound out of tune. Thats where I can hear a clanking sound rather than a clear tone. A common problem with wind chimes.
          I'm not sure what scale would work best, but it needs to be such that when two or more notes are heard, they don't try to cancel one another. That's what happens when the A and B notes collide. Play them both at the same time on your keyboard.
          Wait, I just got an idea. Maybe it could be as simple as just changing the position of the pieces?
          Gene
          • #35
            I could easily redesign it to use only three chimes. That way no dissonance is possible. It also might help as you suggest to make sure the A and B are on opposite arms. I didn't check that.
            • #36
              Here is a three chime version guaranteed to harmonize.
              It uses the notes D, G and B
              http://www3.telus.net/metalshopborea...kit_68x164.txt
              • #37
                Originally posted by Evan
                I used the spread sheet supplied by William Cogger which saved me the trouble of calculating the chime lengths myself.
                Glad to see that my efforst are being put to use. I like the idea of tuning forks and I think I'll have to look into making a set for myself!
                Bill
                Bill
                Being ROAD KILL on the Information Super Highway and Electronically Challenged really SUCKS!!
                Every problem can be solved through the proper application of explosives, duct tape, teflon, WD-40, or any combo of the aforementioned items.
                • #38
                  I am going to make a slightly modified version to use 1/4" thick aluminum. The more mass in the forks the longer they will ring.
                  I was hoping you would notice this little project Bill. Thanks again for the spread sheet. It's very comprehensive.
                  • #39
                    Bronze is the preferred metal for large cast bells. Would bronze make a nicer sounding wind chime too?
                    Allan Ostling
                    Phoenix, Arizona
                    • #40
                      I'm not sure it would. It would probably sound a lot like a cash register...
                      • #41
                        I just wanted to say thanks Evan. I made the 4 chime set on Friday. It took me the better part of the afternoon. I had some trouble with my one singular .125" EM and broke it within 3 seconds of entering the work... I ended up cutting the whole thing out w/ a 3/32 ball end engraver for a dremel. Made 3 passes, broke 2 ball engravers. At long last I got it cut out, and my Wife loves it. I told our two year old that I was helping her make moms present, and she was excited about it as well. So, you have made me a hero in my house for a while. Thank you for the idea and the NC.
                        Thanks,
                        Jason
                        • #42
                          Don't feel too bad about breaking the tooling. The other day I was all set up to do some engraving with a brand new 1/16" solid carbide ball end mill. All I had to do was set the Z to zero. I started running it down to the work and at that instant my Australian Shepard decided to have an absolute barking spaz attack. It distracted me for a moment until the tip of the ball end mill whizzed past my face when it snapped off.
                          Glad to hear it worked out. You need to put a high speed spindle adapter on your project list.
                          • #43
                            >>Can you code a set up in Morris Minor ?
                            Once you get that one done, how about one in Gypsy Major?
                            More realistically, Evan if you have another lookin here, where/when are the farmer's markets scheduled?
                            • #44
                              Every Friday at 10:00 am in Boitanio Park across from Save-On Foods. They moved it from Courthouse Square as they are going to renovate that area I hear.
                              • #45
                                Wind Chimes gCode files
                                I looked at the gcode files. There is ten times as much code there as is needed to make those parts. There are basically straight lines with two arcs on the end of each chime. The hangar has three arcs with straight lines between. Multitiple places in the code have 12 or 13 G02s or G03s all in a row. What gives with that? What am I missing here???
                                Larry
