just picked this up!!
  • just picked this up!!
    i was at a tractor swap meet in the parking lot of my gym and i found this for $25. I dont know much about it all the guy could tell me it was for a tool and die maker.
    Looks good, and sounds like the price was right. What're you gonna do with it?
      Nice score.
      Looks like it's in good condition.
      Just got my head together
      now my body's falling apart
        It's a cast iron surface plate.
        "The truth is incontrovertible, malice may attack it, ignorance may deride it, but in the end; there it is." Winston Churchill
          Sorry, I figured dilligaf knew that.
          Thought it was tool gloat
            i knew it was a surface plate i just didn know who made it or age.
              Well aged cast iron, hmmmm
              <envisage Homer Simpson "pork chops, mmmmmmmmmm">
                Without opening a can of worms here, it would be nice to check it with a known good plate to verify that it is indeed still usable. And it can certainly be restored by scraping, but that may be more than you want to chew. Cast iron plates are very useful in the rebuilding of machine tools, as they have bosses that can be tapped for handles, to be lowered down on the work, and are quite a bit lighter than the stone variety. This one looks to be a nice useful, manageable size
                  If you don't need it, I'll pay postage
                    i think ill keep it for now and i check it and some day maybe even have forrest taech me how to rescrape it
                      Fair 'nuff dilli
                      Have an old pommy mate here that used to scrape and lap CI surface plates to a tenth, just for beer money. He'd be happy to make 3, but can't even get the castings these days
                        I'd be pleasantly surprised if it was (still flat). I've bought several of those small surface plates on Ebay (I know, which is where all the junked tools show up), and none has been anywhere close to flat.
                        I posted pictures of using a flycutter to flatten one that was particularly bad.
                        But the only reason I bought them was to have a sacrificial lamb to practice scraping. Believe me, it's a huge job to scrape even a small surface plate like that.
                          See above Lazlo
                          we can't get seasoned castings!
                          And, fwiw, we're closer to China than you are, and can't even get the cheap granite plates direct
                            Forget about re-scraping. Depending on the type of work you are doing you may be able to use as is. You can check it with an indicator to see if the tol. is sufficient for your work. If not - use it as a plate on your work bench for gen. use and buy a granite surface plate. They are cheap enough - toolroom tol. is +/- 0.0005".
                              Juergen, how do you check with an "indicator" (or blue) if you don't have a reference flat?
