Help me identify a drill chuck taper.
  • Help me identify a drill chuck taper.
    Hi
    I have been given a Tauco Bench drill recently. The chuck however was damaged so I will be replacing it. However I don't know what taper the chuck arbour is.
    The old chuck is a Jacobs and has no. 6A special stamped on it.
    I have tried a chuck from my milling machine with a B16 taper on it but that doesn't seem to fit too well.
    Can anyone help me identify the taper on the drill - are there measurements which would help me identify it?
    http://www3.telus.net/public/aschoepp/tapers.html
      The 6A is obsolescent, but it will probably be a standard Jacobs taper. What are the large and small diameters and length of taper?
      Jim H.
        Excellent - thank you very much
