Another Noobee question
  • Another Noobee question
    Has anyone used a carbide tipped saw blade, the 3 1/2" or 4" variety, for slotting steel, aluminum, etc. on a mill?
    Is there a difference between the carbide on other tools and the material on a saw blade?
    Could such blades be used, for example, on a horizontal attachment for a Bridgeport?
    Obviously, these blades would need to be run at slow speeds, but would it work?
    Any thoughts or experiences?
    Vitَria, Brazil
    This subject has been covered several times here, but I want to learn more about this too.
    I think I've seen pictures of a small 3 or 4 inch 40 tooth? carbide blade sloting some parts here. I think the speed was relatively high though I may be wrong. There was something about the making of an arbor for it too.
    Others will post here with directions to the existing archives ...I hope!
    P.S. I also saw a picture of a blade that jammed and got crumpled into pieces.
    John M...your (un)usual basement dweller
      Try it . What do you have to loose . Just a carbide blade . Try it in a piece of scrap aluminun. You may just learn something . If you don`t do it you want know.Dont let people tell you you can`t do something in a machine shop .You only learn by trying. JUST be Safe.
        I use slitting saw blades on my Bridgeport.
        I run the mill at 600-700 rpms with the blades held on an R8 arbor.
        I use HSS plain slitting saw blades of a diameter of 2½ diameter.
        I have 1/32, 1/16, and 1/8inch thick blades, having no set to the teeth.
        These blades go right through aluminum with no problem.
        The cost of these blades is $13.85 each.
        If you want to move up, you can get a HSS slitting saw w/ side chip clearance for only $45.05 each. (2½ inch diameter)
        If you want to move up again, you can a HSS staggered tooth saw for $60.65 each. This blade comes as a 3 inch as the smallest sold.
        You still want to upgrade all the way to carbide? No problem, you can get a 4 inch (smallest made) with carbide tipped teeth. All 6 of those teeth I might add. This baby will only cost you $131.15 each.
        Since my $13 HSS blades smoothly cut the aluminum, I have no need or desire to 'upgrade' thank you........pg
          You mean like this?
          Have a look over here, they seem to work pretty good:
          http://www.homemodelenginemachinist....hp?topic=166.0
          I think he said that was a $7.95 blade.
          BW
            The price is certainly right. Also, I am in Brazil and it is easy to find small blades for wood, but complicated to find a real cutter for milling slots.
            Also, it seems that one would have to modify the center hole to fit on the shaft.
            I wonder what RPM he is running that blade at and whether it would work for steel?
            Vitَria, Brazil
              Originally posted by BobWarfield
              You mean like this?
              BW
              (groan) yet ANOTHER project! "Turn arbor for cutoff saw"!
              Get thee behind me Bob Warfield!!
              Len
                davidwdyer,
                I am working on a Stuart triple compound. The cut You see in the picture is a piece from that set. I cut 1018, Brass, Alu, plastic and what ever comes in front of me. On the metal, (1018) I use about 850 to 1000 rpm on a Mini Mill.
                on Brass and Alu I go higher. You can feed kind of fast.
                The blade is around 0.055 thick. The cut comes out clean and some times you could use it as is. Since I know now how it cuts I set it 0.060 from what I need and take a 0.005 fly cut after. If you cut to slow a speed the blade will sort of clog and it sounds horrible. The chips get caught in the slot. So higher speed it is.
                The hole is 15 mm. I made s small insert to use the blade on a 0.5" arbor.
                All my metal gets cut with this thing. Will have to make smaller arbor so I get a deeper cut out of it.
                Hilmar
