Huge CounterBores?
  • Huge CounterBores?
    46 millimeter counterbores in two inch plus thick hot rolled flame outs. I was sitting her tonight musing over another Job Layoff , drinking some Beers. I received a Phone Call ,can you counterbore 46 millimeter holes in mild steel. I said sure no problem . Then later it was oh oh theyre huge. What would be the best way to do these? They are a18 inches long 8 inches wide and six holes per plate. Theres six plates of them to do. Thanx
    If you have CNC capabilities, just mill circle it.
    If not, a rotary table.
    Jon Bohlander
    My PM Blog
      Or a boring head.
        Madman,
        What about this thread?
        http://bbs.homeshopmachinist.net/sho...ht=tool+cutter
        The pic is missing, broken link but I'll see ifI can find it tomorrow.
          Madman,
          I've used these in my last shop with good luck. Multi-Tool is the defacto name of these I think. We had 2" plus sizes so I know their out there.
          Hope this helps.
          http://www.jtsmach.com/jtswebshop/Pr...Tools/D337.asp
            sounds to me like it all depends on what you have to work with and your hole locations and tolerance.
              What I want to know is who calls that damn thing a counterbore?
              I have learned, through the mistakes of others, to treat any seemingly innocuous question as some sort of trick. "I need some counterbores" is a vastly different question than "Are you able to <insert simple task here>?" One implies work needs to be done; the other will require a gun drill and five axis VMC, no matter how simple it sounds.
                Good call.
                Good call TD - again.
                Seems that some-one either needs reaming-out or a good dose of cynicism or common dog ---- (fill your own 4-letter word to suit as a substitute for "sense").
                Could also mean that the "Client" has been to another shop which either knocked the job back or quoted on it and the "client" just picked up the term and is "quote- (sucker??) shopping".
                Accepting a job when not having concentrated on it or worse - "buying" the job or "under-cutting" is a sure way to win the "race to the bottom" and "going out back-wards".
                  So what size does he want the counterbores?
                    Where’s the rocket science going on here. Isn’t he saying he has some 18” x 6” rectangular plates, 2” thick. Surely that’s a Bridgeport sized job. Wont they be going through the 2” section. Probably M30 counterbores.
                    You could just drill them as normal, then sharpen your drill to a flat point to square out the seat. For 36 holes. Have you got a radial arm drill.
                    Phil.
                      When did a hole less than 2 inches diameter become huge?? Anyone with a 9x42 mill should do these holes easily. The owner of the plates will have to provide specs to work to. JIM
                      jim
                        Oh, I read that as an 18" deep, 8" wide counterbore.
                        I need to slow way, way down on the whole "reading" thing.
                          I owe Madman an apology for the remark about the hole size being no problem. After I wrote that I got to thinking, what if that guys shop is equiped with Sherline or some similar size equipment? My apologys are offered if that be the situation. My personal shop has larger tooling, so I would not have a problem with a job that size. JIM
                          jim
                            46mm is 1.811 inches, so can you find out if you can go 1.8125 (1 13/16)? Thats a counterbore you can probably buy. Check these guys out, they have a part listed.
                            http://www.supertoolinc.com/
                            James Kilroy
                              Depending on how big the hole is that you need the counter bore for, this tool may be of use.
                              http://www.practool.com/super-drill.html
                              Being an experienced machinist, it wouldn't be too hard to duplicate. It's basically a fly cutter. The original design has a very slight angle on the cutter to cut a very slight cone to sever the outer rim before the inner to prevent snagging on through hole work. The relief behind the cutting edge is quite subtle to allow feed control and gives excellent durability.
                              Cam
