Foley Belsaw tool&cutter grinder
  • Foley Belsaw tool&cutter grinder
    Recently, a good friend bought this machine on craigslist and is temporarily
    housing it in my shop.
    I haven't really used any cabide tooling on the lathe to speak of
    mostly because I have no way to sharpen other than a little diamond paddle
    which I would use to just hone a bit.
    So, I had a couple of brazed carbide tool bits and thought about how to mount the square shanks at the tool grinder.
    I had on hand a 1" tool makers vise and thought it could be used to
    do the job.
    I milled a flat on a length of 3/4" steel rod with a very short shoulder
    to register the long vise edge, pinched the rod and 1"vise together in the
    vise on the mill, and drilled through the two at once to make hole location easy, then drilled clearance holes in the rod which was positioned on top of the set up, and then tapped 1/4"-20
    threads in the small vise, and put in two cap screws.
    The cutter grinder uses 4C collets and it came with a small selection of round collets, I dont know if square collets are available in 4C, hence my use of the small vise mounted to a piece of rod.
    A shot of the holder with a carbide 1/2" square shank tool passed by the diamond wheel.
    A shot of another positioning;
    I dont really know what angles to set up other than positive rake.
    The hard part is trying to SEE what is actually making contact during set up.
    Mike Green
    Mike Green
    One more pic;
    Mike Green
      No grit protection of the Z dovetail ways or the Z leadscrew.
      Foley must think Jesus is going to keep the grit away.
      --Doozer
      DZER
        Mike,
        I half to agree on the dust protection, but overall it looks as though it has the makins for a fine T & C Grinder. Jay
        "Just build it and be done"
          I wish I had that.
            I hesitate to ask how much it was sold for...?
