Neat Rotary Encoder
  • Neat Rotary Encoder
    Markj ("aboard_epsilon") posted this neat rotary angle encoder kit that was being shown at the Harrogate Model Engineering Show:
    http://www.machine-dro.co.uk/index.p...product_id=137
    It's a standard 900 CPR rotary encoder with a quadrature counter/display. So 3600 pulses per revolution works out to 1/10th of a degree resolution. That would be a heck of an upgrade for a rotary table or dividing head!
    Aside from the US dollar being worth less than the Peso, £32 is a great price! I haven't seen these in the 'States yet. If anyone has seen one at CDCO et al -- please let us know!
    ON a rotary tubing bender, that is all you need.. a model 3.. or?? Tie it right to the die radius with a cut-cog belt.. and a spring, sprocket you are degreed.
    Excuse me, I farted.
      yup for a mathematical dunce, who gets middled up easily, like me ...it would make a good buy
      just think
      you say , bolt circle of so many holes
      divide number holes into 360 degrees ...with calculator
      round off to 1 decimal place.
      ( on non dividable numbers...the ones that don't give you full numbers....say 11 holes.... the max your going to loose is something under one degree...you could probably compensate for many more holes by adding and subtracting .1 of a degree every so many holes ...let the maths geniuses here ...figure that one ... )
      move rotary table that number of degrees ..
      drill hole and zero ..........
      move table again
      no counting turns ...just forward a bit ...back a bit ... lock the table and gotcha....and no getting lost either.
      all the best.markj
        3600 divisions on a 4" diameter circle is about 3600 divisions in 12" (12.566" if you're picky), or a division every 0.0035". That might not be good enough for some things, and it would be larger for larger diameters....but it ain't bad. And for smaller diameters, of course, the spacing would be smaller.
          Wich the bender, it is a 4.5 Radius, or a 9" center line circle turning a .75" UL belt cog. Not got my head on straight to do the math in my head, but that x pulses per revolution.
          Now making it read the "degrees" with the pulses? how? does it program and do divisions like the plc did?
          It'd be a calculator thing otherwise..and then the dreaded 65,000 reset thing.. Lots of small cpu's and readouts won't go that high or error out.
          LOOKS like it is meant to run at 1:1 ratio, no internal math..
            Never mind the math - feel the reality
            Nice item for feed-back!
            Never mind getting bogged down in the "numbers".
            The reality is that in its basic form the item is accurate to 0.10 degree = 6 arc minutes which is about as good as you will get with a vernier or digital protractor or an average rotary table (direct reading and not interpolation).
            Sin 0.10 = Tan 0.10 = 0.0017 = 0.0017 per inch = 0.017 per 10".
            As lazlo says, that is a lot of "handiness" for very little money so it is very good value for money.
            Also it needs no permanent mounting. A little bit of ingenuity and a bit more common/shop sense can do wonders with this item in the shop or anywhere.
