Coloured Plastics
  • Coloured Plastics
    I'd like to machine up various coloured knobs for the controls on a tractor. Preferably bright colours. What plastic is suitable for this? It needs to be machineable / threadable, hard enough but shatterproof and available in 35mm or so round bar stock. Resistance to diesel would be nice - the stuff seems to get everywhere!
    Thanks,
    Ian
    All of the gear, no idea...
    High Density Polyethylene, (HDPE,) might work. It machines easily and comes in white, black, blue, orange, red, and green, (that I know of.) It is unaffected by most solvents. Where to get it? Try a plastics supplier. Around here, someone is packaging slab offcuts in 3 lb bags, which is handy for little jobs like slippery feet on heavy machines. These dont move on a concrete floor, but CAN be moved with a bit of effort. I assume round stock would be available.
    Duffy, Gatineau, Quebec
      Ultra High Molecular Weight (UHMW) polyethylene comes in many colors.
      ebay (US) has Yellow, Pink, Blue and Orange available now from one seller, might make up a box with your preference of colors.
      Search "UHMW"
      It machines just fine, is resistant to many fluids, should be good for your application.
        That isn't a very demanding application except for one thing. They need to be UV resistant. For that the best is a UV stabilized HDPE product. Check with a marine chandler or outfitter for a source.
          delrin would work. You can get drops off ebay in different colors.
            I just saw a posting on PM from someone who uses old billiard/pool/snooker balls for this. Apparently they machine nicely, and at least some are solid color all the way through. The person in question is from the UK, where I guess old snooker balls turn up more frequently than here in the states, but I wonder if old bowling balls would work.
              Try pen turning supplier:
              http://www.pennstateind.com/store/pen-blanks.html
              diameter might be a problem, but the variety is good.
                bruto, old bowling balls are not a good choice. I had to machine a ¾" groove about `1 ¾" deep in a bowling ball for a friend. The inside is some sort of black stuff mixed with cork. It cuts dirtier than cast iron and is extremely abrasive.1 pass to full depth would put a very noticeable radius on a HSS tool, had to sharpen every pass. A grinding wheel is only slightly less abrasive. Also, the material does not tend to produce a nice finish, even in the 5 seconds the bit stays sharp.
                Ed
                  Ed
                  I was not going to stick my nose in a thread about plastic , but I just can't help myself.
                  WHY WOULD ANYBODY IN THEIR RIGHT MIND USE BOWLING BALLS FOR TRACTOR KNOBS? .
                  STEVE
                    Thnaks all,
                    Great replies as usual.
                    Evan, the tractor will be spending most of its time under covers or indoors when not in use, so UV resistance shouldn't be a problem (the driver is less UV-resistant than most plastics).
                    Good tip on the UHMW - the guy has some interesting colours; I'll see if he can put a custom pack together.
                    Snooker balls; mmm...
                    Ian
                      STEVE
                      I think he meant to cut a bowling ball up and turn knobs from the smaller bits.
                      bollie7
                        Now I want to know why? And how?
                          bollie7
                          Yes, that was the idea. They would be a little ungainly otherwise.
                          Thanks to the Doctor for the warning. I thought some might be solid plastic.
