Another jet question
  • Another jet question
    I have a Jet 10-24 lathe that was used when I bought it 20 years ago. (Doug, works fine).
    I'd like a 4-jaw chuck to fit, but the spindle is 2"-8TPI.
    Are such chucks available, or do I need to machine a back plate to fit?
    Thanks.
    I'm not sure. you might try jlindustrial.com.
    Also enco. if it's standard there should be
    one.
      Doug,
      Thanks. Tried today. It's either from Jet or machine a plate.
      Not bad, though, that Jet still supports a 20-year old machine. And it was cheaper than the chuck and the plate.
