New Style Water Well Dowsers?
  • New Style Water Well Dowsers?
    Electric resistive logging of water wells was adopted from the oilpatch. (Schlumberger-Houston) Original measurements required four conductor wireline, or multiple trips with two conductor. Modern water logging is done via shielded coax, with a downhole PCB encased in a pressure proof tube container, 2 X 30 inches. Information provides thickness of water bearing strata and water quality.
    Pics are of bar of 303 SS being whittled for end caps, O-ring seals, electric conductor bulkhead/seals and mechanicals. Female threads on long tube were machined by real shop with nice size lathe. Threads are 1 and 2 inch Acme, 8 and 10 TPI, single pointed manually on 9 X 20 lathe.
    Would be a hard way to make a decent living.
    G
    Take this back to the PM site before it gets out of hand.
      Guido... please, please take this over to PM. DT wants this thread there
      Would be best if you mention they are made in china though.
      Do they work? Ooops.. do I really want to ask that?
        I have wanted for a long time to do some experiments with using a seismic thumper and some geophones to see if it is possible to map out shallow strata to find water. I can't think of any reason why not but the main catch is the software which I would have to write myself.
