South Bend 13 4 Position Carriage Stop Jammed
  • South Bend 13 4 Position Carriage Stop Jammed
    Hello,
    I just received a South Bend 13" 4 position carriage stop and it won't turn. Upon examination, it appears that it has had a recent paint job. So, I am thinking that some paint ran down between the casting and the barrel of it. Will soaking it in paint thinner work to free it up?
    Thanks,
    There are only 10 types of people in the world: Those who understand binary and those who don't.
    My guess is, probably not. Paint thinner typically doesn't do much to hardened paint. Won't hurt to try it though. I imagine you'll need to disassemble it to get it to move (watch out for springs and balls that may want to go flying).
      use lacker thiner in a closed contianer, metal or glass.
        But lacquer thinner will strip the paint right off...
        I'd suggest SGW's approach: take it apart and clean it. If the paint is good, but has run down inside the barrel, take an X-acto knife and trim the edge on the barrel so it doesn't crack when you pull it apart.
