3 wire thread measuring
  • 3 wire thread measuring
    I've been trying to measure thread depths using the 3 wire method without much success. My problem is how to hold all 3 wires steady and in the threads while making a measurement, especially with the work still on the lathe?
    Am I making this harder than it really is?
    What?! You don't have 3 hands?
    A small chunk of modeling clay, or some tape, helps.
      Grease, blop of grease and one wire on the bottom, blop of grease and two wires on the top. Open your mic up a bit wide, catch the bottom wire, then come down on the top two wires. A piece of cardboard under the chuck helps for when you drop one.
      I've also seen people stick them into sponges, that seems to work pretty well, though I'm comfortable with grease.
        Also, check Marv Klotz's site for 3 wire calcs (among many other workshop/maths utilities)
        Just got my head together
        now my body's falling apart
          Holding three wires for thread measurement
          I'm a tape guy. A strip of duct tape 3/4" wide about 1" longer than half the circumference. Lay two wires parallel cantered about 1 pitch apart. Apply the end of the tape to lap the ends of the wires by 1/2". Same on the other with the remaining wire. Carefully fold the tape over to capture the wires so no stickum shows.
          Bingo! The wires are firmly captured in their most usable position. Grab them by the tape with thumb and forefinger and by using the knuckle of your middle finger bring the single wire under the thread. Use the other hand holding the mike to guide the double wires over the work. Take your reading.
          If the wires are small and the thread large you may wish to tape the other ends of the wires to make a loosely fitting circle that goes around the work. If the tape is bright red they will never get lost if you drop them in the chips.
          If you get them oily be prepared for the tape stickum to slowly dissolve into goo.
            I guess the thickness of the grease, clay, etc. in the root doesn't affect the measurement much?
            Forrest: I understand your tape method - I'll give it a try!
              Get a small piece of soft foam, like the black electrostatic foam that chips are shipped in. Poke two of the thread wires into the foam along the bottom, and snug it up under the thread. The poke the remaining thread wire into the foam over the top, and use the micrometer jaws to clamp the three wires, held by the foam, together.
                Re: clay. You wouldn't put it on the threads; you'd stick the 3 wires into it, like with lazlo's foam idea (which sounds handier than modeling clay....)
                  I had to do this not too long ago and I used a chunk of green floral foam from the craft department at Walmart. It's made to have stuff stuck into it. Works great and really cheap.
                  Stuart de Haro
                    My machining textbook shows the wires being held with rubber bands.
                      Just put a little grease on the thread top and bottom or all around if you want. Put the wires in the thread and measure bringing your mike up against the bottom wire first. Just like bobw53 said. The small amount of grease will not effect your measurement.
                        We really need a sticky FAQ. This question comes up every couple of weeks. Same as "how to center square stock", ...
                          With all due respect I've read this forum several times a day for the past 18 months and don't recall seeing this one before. Not that it shouldn't being a sticky - especially with the search feature not working well right now.
                          Thanks for all the ideas guys - I can't wait to try them out!
                            Holding thread wires w/only 2 hands
                            Thread Wires...
                            In that thread we talked about grease, scotch tape, silly putty, sticky tack, and my favorite -- sticking the ends of the wires in the black electrostatic foam that chips are shipped in.
                            But Airhead's post #15 is a classic:
                            http://bbs.homeshopmachinist.net/sho...2&postcount=15
                              I use modeling clay or Silly putty. Being a mold maker Silly putty is standard fair and in all moldmakers boxes anyway.
