Hi Folks, Here's a little progress on my junk bin engine. Need some advice on deep hole drilling. have tried twice now to build a stepped sleeve for the crankshaft which accomodates the flywheel and pulley.
Using the lathe, first time I tried sneaking up on the ID with 3 bits but the bottom of the bore was out .007" side to side over the 7/8" Dia. sleeve, I could see this by eye and knew it was wrong before I measured it with my caliper.
The second time I tried 1 bit, measures ok with the caliper and it looks good to the eye when I spin it on the shaft. But once I put the flywheel on I can see a slight wobble. Measured with a dial indicator, has run out of almost .005" on the outer edge of the wheel.
I am trying to drill a 15/32 hole 2.200" deep. My boring bar is to big to fit so I can't use it. (wish I had this problem elsewhere).
What am I doing wrong?
Cheers, Bob
Cheers, Bob
