Would have been a good lathe...
  • Would have been a good lathe...
    for someone,before the g'mint got hold of it.
    http://cgi.govliquidation.com/auctio...tionId=1790384
    Nice! What did they do? Buy a new lathe then just sit it outside???
    Doesn't look like it saw much use does it?
    I see the "only" paid $12,000 for it!
      Government acution,they like to let things sit outside and season before they sell them
      They are famous for destroying large woodworking bandsaws(Oliver Yates Tannewitz)typical method they use is the pallet back flip meaning the 4,000lb cast iron saw is flipped over on it's back most times breaking the frame.
        yep, i watched this sit for awhile drooling over some mills and lathes. seems most all are stored out side and left to rust awhile before selling.
          But the worthless office chairs are all covered up carefully.
            This is all done stratigicly so the bidding will go sky high and bring in more money. If the machines were kept in the condition they were in when removed from service no one would bid on them, nothing to restore or fix . Nothing quite like the satisfaction of bringing a priceless treasure back to life.
            Brooklin Bridge For Sale...Cheap
              I do not think that South Bend made many of that model. Seems that no one wanted to pay that much for a lathe that had the South Bend name on it. However, from what I have been told, it was a very good lathe. Gary P. Hansen
              In memory of Marine Engineer Paul Miller who gave his life for his country 7-19-2010 Helmand Province, Afghanistan. Freedom is not free, it is paid for with blood.
                Yep,on a par with a 10EE,but with one advantage the drive is much simpler.
                  That is just surface RUST . every day thing around here . Oil and steel wool are scotch bright then good as new .
                    Your Tax Dollars
                    Your tax dollars. I've ranted here before about the governments "surplus storage methods."
                    What they buy doesn't come "directly" out of any one individuals pocket, so I guess it is looked at like, "What ever happens to happens to it". They apparently don't care. Let it become, or at least look like a P.O.S., then try to sell it.
                    Imagine if the GOVERMENT entrusted YOU to take care of thier property, and you did so in that manner.
                      I can't find the link right now, but there's a beautiful monarch on machinetools.com in government storage - they want 100k for it. Immaculate condition, from first glance. 20"x144" iirc, D2-8, two carriages, full length template holder, dual tracers. What a crazy machine that would be to own.
                        On the outside,but I have noticed that gearboxes that won't normally hold oil will hold water.
                          Maho mill at the same sale,surface rust,water in the cabinets and probably the servos too
                          http://cgi.govliquidation.com/auctio...tionId=1792863
