Broke into the 60's (62.5 MPG)
  • Broke into the 60's (62.5 MPG)
    Who the hell needs a moped, car ran cool as a cucumber with EGT's just 50 degree's F. max over stock, 10% city driving and the rest hilly and also a little blend of crap ethanol -- there is no reason I should not be able to get into the 70's on occasion driving 60 to 65 mph on the flats, It really is amazing, im very happy with my Mods. and actually way beyond my expectations, Ya get pro-active - sometimes it actually pans out and liberates you.
    Im approaching TWICE the mpg highway rating on www.fueleconomy.gov of a 92 toyota tercel
    What is it?
    What did you do to it?
      Phase one; You will find in the search "broke into the 50's"
      For the most part its within everyones "efficiency percentile" reach.
      Phase two you will find some info in "machining new value's of a potentiometer" Its still on page two.
      Somewhere inbetween the two threads is another showing my new air/fuel mixture and exhaust temp gauges, you might get lucky by punching in "gauges" into the search.
        That's wonderful , are you going to try for 70 mpg?
          Broke into the 60's
          Think about it but my wife got 57.5 mpg in a standard C Class 270 CDI Merc Estate car fully loaded and with an automatic box and 70+mph.
          None of this fancy gadgetry unless the radio counts.
          The Hyundai 1.5 litre Diesel is advertised to do 75mpg.
          Really, my 1.1 Hyundai Getz which is petrol does near to that with the aircon blasting and me - singing ' Viva Espana'.
          It does suggest the Legion of Lost Causes!
          Now there is a Beemer car which does------------------------Better not, Normie- the Yanks are getting touchy!
            Is your gal. Imperial=4.54Liters or 160oz
            or a USA gal=3.78Liters or 128oz
            Doug
              Avi, I like perspective also, here's some from my end, while I will never argue that diesels have huge efficiency advantages I will state this - Its mostly in part due to them not having to come up with a "proper mix", They just throw a tiny little fraction of a drop of highly atomized/underpressure fuel into a high comp.chamber that was fed full bore open with no throttle plate and fire off their load, its a great way to go - but for the most part what your rating is is what your going to get --- you can make some mild improvements but you will never be able to achieve the efficiency percentage gains of what iv just done, Um --- need I remind you that not only is my rating higher but my fuel is cheaper And Vmil brings up a great point --- what size gallon are you talking about? mines US...
              As far as your 1.1 hyundai - I will not only outdue it I will also drag it sideways, I push a little button that disables the Potentiometer and piggyback oxy sensor and the 1.5 tercel is capable of 120 mph on the flats, So no- not a whole lot of gagetry But a few very fun gauges to watch
              Keep in mind one thing also --- I have not gone LOP yet, if im fully capable of getting into the 70's right now it means that the 80's are possible if I set my steed up to run Lean of peak, tell me it cant be done (please)--- and then sit back and watch me make it happen. Some call it "touchy" But really whats behind it is competitiveness, think this is "bad" Things really get ugly when I pedal my mountain bike. --------
                That's very impressive AK -- both the mileage and your skills and ingenuity to tune the motor.
                We've been talking about "doing something about it" -- you did!
                  Thank you Laz, You know what im starting to realize?
                  it really is becoming the new "status" symbol -- in general consensus it's actually becoming very "uncool" to drive a massive hummer, My how things are flip flopping -- Iv got customers wanting me to do this to there cars, Although I do not think the general public is ready to be rolling down the highway mixing up a batch of fuel for the immediate demand at hand I have two appointments with two "efficiency gals" that I need to pop the hood and see if I can incorporate "phase I" into their throttle system, tire pressure's and synthetics and then a long drive together to teach them the basics of efficiency driving habits. For the first time in a long time Iv rekindled my love affair with the automobile as I feel I can make some changes - at least on a local level...
                  Side note; did a clutch job on a 97 suzuki esteem last week -- pop the hood and whats staring back at me? a progressive ratio throttle control -- it was made of plastic but hey.
                    Broke into the 60's
                    Ah but I have two cars which will make your 'whatever it is' cough and splutter. The Merc in bog standard will pull 146mph and I suspect that the SLK will turn both heads and much the same speed ( both have governors as with Krautmobiles).
                    The MiniCooper?????? Come on Sunshine- I tuned the original one way back in 1963 and this one is -well, enough to get really excited about.
                    The Hyundai is merely - a Spanish replacement to an overloaded donkey!
                    Cheers me deers
                    Norm
                      Norm
                      Not going to argue with that, only thing Iv ever owned faster was My CBR F1 600 hound dawg, after I ram aired it it would do 156, but that was indicated and the jap bikes are always a little higher than what your actually traveling, Plus Id hate to think what kind of MPG's I was getting at that speed, although with the double the speed quadruple the drag factor I hate to think what the mercruisers consuming also
                        NOW that diesel costs over 15 percent more than petrol
                        you can knock 15 percent off those figures
                        so if ive calculated right
                        your 57.5 mpg is actually rounded up 49 mpg
                        then take away a couple of thousand quid for a new diesel injector pump every 4 years
                        all the best.markj
                          He still hasn't told us what Size gallon? this is a huge diff., and a mercruiser getting 57.5 on a U.S. gallon does not sound right at all, esp. when the volks jetta's TDI was rated about 5mpg's UNDER that.
                            Broke into the 60's
                            Quite a few things arise! I am writing about a absolutely standard vehicle which is running on English gallons. At the moment the diesel injectors are 7 years old and obviously show no signs of needing to be replaced.
                            The next point is that your 'boomer' can't be insured in the UK or anywhere else in Europe.
                            The next point is that if a modified car is undeclared to the insurance company, it is NOT insured.
                            Err, message understood?
                            Now don't get this idea that I am a Johnny Come Lately, I passed my driving test- the car one, on a 1935 Morris 8. I also have double distinctions British City and Guilds in Motor Vehicle Restoration. Unquestionably, what is not that honourable company called 'Back Lane Industries'
                            OK?
                            Norm
                              Good show Boomer,one question though,where are you picking up the EGT? At or after the manifold?
