questoin on mini mill
  • questoin on mini mill
    can i do milling using the supplied 5/8 chuck and no do any damage to me or the machine,, i dont have any collets yet but was woundering if its ok to do some milling , would it be better to use my metabo keyless self tightening chuck instead of the factory chuck
    Expect that eventually the milling cutter will come loose and damage your table or work. Milling sets up a different vibration than drilling.
    Bob
      I wouldn't try it, especialy if the chuck is held on the shank with just a taper the loading on the chuck from the cutting will rattle the chuck off the shank and send it where you do not want it.
        I have a Jacobs chuck in my mini mill and also some collets and holder. Both work fine for the kinds of work I'm doing. I wouldn't consider using a keyless chuck for anything but drilling.
          well alrighty then i guess ill have to waite till i can afford some collets for it then , I dont want to damage the mill
            Definitely not recommended. The side load imposed by milling will almost certainly "walk" the chuck off its taper mounting shank, sooner or later.
              "woundering" Yeah...that's a good word for what you were asking about
              Same answer....drill chucks can loosen under side loads...especially the keyless type. I have one of those really nice, really expensive Jacobs precision keyless types (I nearly stole it at the price I found it for...I'm not rich). Its even designed so that it tightens itself under use. I used it with a large drill which started some vibration in cutting and the bit immediately came out of the drill. Not to be swayed from danger, I tried it again with the same result.
              Paul
              Paul Carpenter
              Mapleton, IL
