DRO on quill
  • DRO on quill
    I purchased a BP clone with a three axis Acurite DRO. The third scale is on the quill. I am getting into the habit of using the knee to get the work close, and then using the fine feed on the quill for my cuts. Is this a bad habit? Someone said I should put a scale on the knee and use it, but the quill seems to work fine. I bring the knee up very close so my quill is not extened too far, but I just wanted your opionions. It seems to work fine, but I don't want to develope a bad habit. Thank you. Respects, Verne
    get both and a scale summing box!
    -- really, the only bad habbits are the ones you don't want to have. if you like it, who's arguing and why do you care?
    I like it on the quill. many if not most people do.
      I havent any experience with a DRO on the Z axis so I have always used the knee for
      fine adjustment in the Z axis. How do you get a fine feed on the quill? On the Bridgeports
      I've usd the quill would be VERY difficult to feed a thou or so, while the knee is very
      easy.
      ...lew...
        Use the fine feed on the head (The handwheel that is most often missing.)
          My BP clone came with 2 axis DRO and I added one of the caliper types to the quill, its real handy for drilling with the quill handle, but that about all I use it for.
          On moving up from a mill-drill and getting a knee type mill, my friend and mentor said "when you get used to using the knee, you'll almost forget the quill has a handle" and I thought he was crazy! No more! The knee will give MUCH more finite movements than you could ever get with trying to feed the quill.
          I think I'd like a DRO on the knee someday though......
            Where can you get a quadrature summing box? US Digital used to sell the EAdder box, but they recently discontinued it, and I can't find anyone else who sells one?
              I have a Z scale on both and a serial A-B Chanel switch box.
              A for Knee B for Quill.
              PaulF
                Paul, your switch box takes DIN connectors, right? If so, that's probably a quadrature switch -- did you build it yourself?
