Peristalticpump hose?
  • sdeering
    Yep. I have browsed that site watched the vid too. The guy has some great ideas I like the bobcat mixer.
    Hears a pick of his hose. i could order from him but I would rather find somthing in my area.
    http://shop.monolithic.com/products/peristalticpumpline
    I’m thinking a smaller version.
    I may have to go to our hose supplier and have a look.
    Stephen
  • digger_doug
    something like this ?
    http://static.monolithic.com/gallery...500/index.html
  • sdeering
    Thanks DR. nemo
  • doctor demo
    Originally posted by sdeering
    http://www.southern-tool.com/pdf/mul...rayer-1099.pdf
    Since I have the wand hose and air I think building a parastalic would be quite simple, except for the hose material.
    Anyone else?
    Stephen
    Delta Rubber sells all kinds of conc. pump hoses here in Calif. I don't know how big a footprint they have globaly though.
    Push come to shove You could call and get a hose spec. and go from there.
    Steve
  • sdeering
    This is what I have actually 2 of them, except for the hose and wands.
    I am using a 3/4" hose and I built a wand. I am using air from my shop comp. I think the stator is wore out. If I put my hand over the end of the hose and stop the flow.
    I think I am mixing my plaster thin enough. Its not pluging it just has poor flow.
    I was thinking of renting something but there is nothing in my part of the province.
    Anyone else?
    Stephen
  • Guido
    Progressing cavity pump styles come in many flavors, ie. pressure vs volume. Great for moving abrasive/fluid slurries. Pressures to 17 feet of head are 'no chore for a stepper'.
    For moving cement based stucco materials and mixing with water, Google up Reed Concrete and Gunite Pumps. Depending on where you are, weekly rental of a pumping system and compressor for a one off job, will greatly simplify your project.
    I hesitatate to suggest it, but more than one working gunite machine has been cobled together by those so inclined.
    G
  • sdeering
    started a topic Peristalticpump hose?
    I'm pondering making cement/stucco pump.
    Anyone know what type of hose would work the best in this application? Im thinking 1to2".
    All I have found Googleing is, it is made of open-cell polyurethane, has a combination of outer fabric reinforced shells with inner “rubber” walls that have a tremendous “memory”.
    I will be applying 1” of stucco to the inside and outside of a 30x40x17 foot straw bail building. I don’t want my one arm to be twice as big as my other at the end of summer.
    I have been experimenting with am essic progressive cavity pump, I think designed for fire barrier material. It works but I don’t think it will do the 17’ of head needed.
    Thanks for any help.
    Stephen
