Help with digital micrometer
  • Help with digital micrometer
    I have a digital micrometer which wont hold zero, it zeros OK when I press the button but when I open the anvils and close them again it will show a reading this reading can be anything. The instructions tell me that if erratic readings occur remove the battery and short the terminals out in the micrometer, I have done this several times to no avail. Also after fitting a new battery it discharges in a week or so with the instrument unused in its box. Any advice other than chuck it away ? David
    Sell it on ebay.
      Originally posted by tattoomike68
      Sell it on ebay.
      ... and don't forget some flaking before you take pictures of it.
        Yep! You can't beat "mechanical" things. Electronics isn't here to stay. :-)
        ...lew...
          No 8 coats of krylon, spindle, barrel, faces and everything, make it look dip painted.
            if chuck it an option i'm guessing its not a Starrettm, Etalon or Mitutoyo, if it is call them, if it isnt' chuck it.
              "g"
              Use it as a "G" clamp.
                you can send it to me i like free stuff if your going to picth it and i love to tinker with electronics
                  If you need a digital micrometer, get one of these.
                    [QUOTE=Richard-TX]If you need a digital micrometer, get one of these.
                    [/QUOTE
                    Thats the one I have but with an "Axminster" logo on it bought in the UK.
                      J&L do a 0 -30mm one made in Switzerland by Tesa badged up as Brown and Sharpe, they sell for anout 90 UKP here but are often on offer at about 45 UKP.
                      I bought one as a lot of my small motor work is 30mm or under.
                      Good micrometer very accurate and well pleased with it.
                      Only problem was I dropped it one day and lost most of the display.
                      A quick phone call to J&L about repair and it appears that it's a fixed price repair - yes you have guessed it 90 UKP and not the offer price.
                      So just binned it and put it down to experiance, I'm loath the shell out another 45 notes when the same thing can happen so it back to roughing out with the cheap digital veriers and finish up with the old trusty manual micrometers.
                      David, just looked on Axminsters site and the two they show are not like the Fowler in Richards post.
                      In fact the more expensive one looks like the Tesa one from J&L but only in 0 - 25mm.
                        Please take this 'advice' and other considerations in the intended spirit of assistance,
                        Have you cleaned the anvils of any small gunk before setting zero, also close and hold to the light when shut to show any inclusion that may interfere.
                        Digi mikes often read to 0.001mm or 0.00001", doesn't take much to muck that about, perhaps even warming in hands or warm shop.
                        After zero have you measured a known size, that you checked with a screw mike to compare.
                        Are you aiming for tenths of a thou or is it out by much more than a thou?
                        Hope you resolve it
                        Al
                          i have 2 0-1 micrometers not digitial type as well as 3 sets of digital veriers , i much prefer the digital veriers over anything at this point i do alot of metric stuff and alot od the tme over 1 inch but even for the small stuff i seem to have no problem turnning anyhting to where i need to be at ,,if i was to start having a need for the 0-1 i think id go digitial now as the manule ones frustrat me to no end...
                            I got this dandy off eBay a couple of weeks ago from our own JC Hannum. A good cleaning with A/C flush and new batteries gave it new life. I've been using it to check all my standards and gauges. Dang nice piece of equipment. Found out my Atlas/Craftsman tailstock was out by .000025".
                              QUOTE
                              Found out my Atlas/Craftsman tailstock was out by .000025".]
                              How can you expect to do accurate work when your tailstock is that far out.
                              MBB
