Bridgeport J head step pulley speeds
  • Bridgeport J head step pulley speeds
    Would somebody please post the speeds chart for a step pulley J head, both high and low range?
    Thanks
    Low- 80, 135, 210, 325
    High- 660, 1115, 1750, 2720
      Or if you have a 2-speed motor like me, the speeds are as follows:
      (UK 50Hz)
      Low range: 67-115-180-275 / 134-230-360-550
      High range: 550-920-1500-2300 / 1100-1840-3000-4600
      Peter
        Or if you have a VFD the range is 3 RPM to 4000 or so in 8 steps..
          Forrest,
          Thats mean . Accurate, but mean
          Robin
          Robin
          Happily working on my second million Gave up on the first
            Thanks X39 - exactly what I was looking for.
            So the gear reduction is somewhere around 8.3:1? If I do the numbers, I get anywhere from 8.25 to 8.333.....
            Anybody know the actual gear ratio?
