CNC Dentistry
  • CNC Dentistry
    I just got a tooth crown, CNC-machined in the dentist's office while I waited, from a 3D model generated from digital images of the original tooth and the "stub" after the dentist had ground it down. The whole procedure, start to finish, took a bit over 3 hours. This is the company that makes the equipment: http://www.cereconline.com/
    It was quite amazing. The CNC machining was done on a little desktop unit with two spindles that machined the ceramic blank from opposite sides. Once the machining was done, the dentist applied a clear glaze and fired the crown in an oven before installing it.
    thats not exactly new but fascinating much quicker than the old way but in my opinion not as accurate.keep smilingAlistair
      The only thing keeping CNC dentistry out of your mouth is the head crashes -- ouch!
