Although I have a garage full of old brake rotors, I hate to machine CI in the shop. Stopped at Autozone this evening and had the girl grab any small (thin) rotor off the shelf. She looked up the price and it was $20. I forget what car it was for but here are some very careful measurements ... quite impressive.
Rotor thickness variation measured at 4 quadrants, at 2 diameters:
+/- 0.00005"
Height from outer face (at wheel hole pattern) to rotor surface (also 4 quadrants):
+/- 0.0001"
In short, these Chinese rotors are on a par with the best quality parallels !
Of course, they are soft and they have a fine turned, not ground finish and these accuracies are only possible because the faces of the mics ride on (and integrate) the surface peaks.
Still darned good for $20 and it let me tram the mill within 0.0005" across about 8" in 5 minutes. A large diameter ball or roller contact point would allow the DTI to see close to the accuracies listed above.
Den
+/- 0.00005"
+/- 0.0001"
Den
