Finish ing Fiberglass
  • Finish ing Fiberglass
    Just bought a Big Foot Fibergklass Camper. Nice unit all Fiberglass but the outside finish looks like the clear is peeling off a bit. How would you fix this? Buff it out >??/ thanx
    Unless someone sprayed clear on it, fiberglass generally starts with a gelcoat sprayed into the form. The gelcoat can be a color or clear. In either case, you can degrease, scuff/sand, clean then shoot clear over it. What ever you do, don't sand down into the fiber or it will have to be sealed.
