Help--Southbend 14 control wiring
  • Help--Southbend 14 control wiring
    Anyone have a control wiring diagram for a Southbend 14 lathe? Need diagram for speed control.
    I'm new to this group, hope I did this right.
    Thank you
    Rog
    The SB 14 I had didn't have any speed control. Just a simple "Start - Stop" circuit for the contactor.
    Are you incorporating a VFD?
    If so, refer to the VFD manual for wiring instructions
      The later model Turnado and gear head lathes had VFD speed controls and other electrical circuitry, possibly it is one of these. A model number or name would help.
      You might have better success by asking on the South Bend forum at PM;
      http://www.practicalmachinist.com/vb...splay.php?f=25
      Jim H.
        Help Southbend 14
        lathe is Model Southbend 14
        Serial #00192TT
        control diagram #75-B660718
        Lathe has 2 speed gear box with variable speed pulley on motor shaft. I am not installing a VFD at this time. The variable speed is factory installed. I need a control wiring diagram to help someone else with a problem they are having.
        Thank you for your reply.
        Rog
