Hi
I have this comercial sprinkler/irrigation system part. (I'm fixing it for someone else). It is a cast brass part and has a gear at one end and two other holes into which sprinkler arms are fastened. (The gear is used AFAIK to drive the unit as the sprinkler arms rotate)
One sprinkler arm has broken, leaving the broken end "corrosion welded" into the central part.
I have since managed to extract the broken piece, the thread suffered some minor damage in the process. I would like to clean up the internal thread and put a new thread on the broken sprinkler arm (as well as on the none broken arm, making both arms the same length).
As the device (we believe) was made in the USA, would I be correct in thinking this would be an NPT thread?
The sprinkler arm has an ID of about .5" so I am guessing this could be a 1/2" NPT thread. What would you think?
FWIW, a 5/8" UNF bolt screws (loosely) into the internal thread.
Thanks for your help.
