OT: Electrolysis "fix" needed for U-joint
  • OT: Electrolysis "fix" needed for U-joint
    Can Anyone help me here? Typical GM driveshaft dilema. I cant get the steel U-joint cups to release from the aluminum bores on the driveshaft. I realize the have a poured plastic retaining device of some sort. I thought I could just press them out with a vise but they seem seized in place ??????
    Bricolage anyone?....one of lifes fun games.
    Well, if you realize the plastic retainer is there, did you remove it? You will never get them apart if you don't. A heat gun or propane torch will do it. Heat the yoke, the injected plastic will boil/ooze back out of the holes it was injected into, then you can pop them apart with a vise and hammer. Best way I have found without a press, it to open the vise jaws wide enough to support one yoke horizontally just resting on top. Strike the other yoke with a BFH at the base of the ear, and it will drive the cap out upward. It is very fast, and will pop nearly any automotive u-joint.
    Later,
    Jason
