Semi-steel
  • Semi-steel
    Maybe every other chip maker knows this but me (I'm kinda new to machining), but in the machining catalogs I see the term "Semi-steel"... usually describing lathe chucks. What's semi-steel? Is that a cross-breed between cast iron and steel?
    Lynn (Huntsville, AL)
    Yes. Slightly tougher than cast iron. If you want more info check machinery's Handbook or US Steel's "Making and Shaping of Steel"
