Harbor Frieght Vertical Milling Machine
  • Harbor Frieght Vertical Milling Machine
    I'm looking at the Harbor Freight mini knee mill vertical milling machine, #40939.
    see: http://www.harborfreight.com/cpi/cta...emnumber=40939
    Does anyone have any experience with this machine? It looks like it could be a good small mill as an alternative to the mill/drills that are available.
    That is known as a 6x26. Generally pretty good smaller machines, they do seem to be falling out of favor to the newer dovetailed RF-45 style machines. I had the WT version of it and was quite happy, other than it was sort of small. Yahoo has a good 6x26 group, as well as the archives here.
      I don't know where you live but around Detroit used Bridgeports come up on Craigslist from time to time for that price, if you have the room I would consider that a better option.
      http://detroit.craigslist.org/tls/866809921.html
      Brandon MI
      2003 MINI Cooper S JCW#249
      1971 Opel GT
      1985 Ford 3910LP
        Thanks
        Thanks for the comments. I would love a Bridgeport, but I don't have the room. The machine would need to go in my basement which is only accessible by stairs.
        A small machine would suit most of my needs. I'm considering a mill/drill but I saw this machine and thought it would be a more rigid platform.
        Do these machines have metric or inch lead screws? Can they take a standard power feed unit?
        I will check the 6x26 group as well.
          I had a 626 from Warco in the UK before I got a Bridgy.
          Very capable little machine that can do lots of good things. However, what really made me go for the Bridgeport was the minimal 6" travel on the Y axis, which drove me mad on a few occasions.
          No problem with fitting power feeds, as you can see from the Warco picture below.
          Peter
            They're really nice machines. I researched them a little ways back and read lots of good comments (excepting the obvious size limitations). I even went so far as to go to the Grizzley showroom - about 3 hours from me - with the intent of buying one. Unfortunately (or fortunately, as it turns out) they were sold out at the moment.
            I can say that the Griz version costs a little more than the HF clone (which I've never seen in person) but the fit and finish are very nice anf it had a nice, pretty solid feel to it.
            As luck would have it I went home and found a 3/4 size Enco bridgeport clone on craigslist for 1200 the next weekend and haven't looked back since.
              Been using one in daily production (see my other thread) for five or six years, and quite like it.
              No used Bridgeports in my neighborhood, so HF is a viable option for me.
              It is the only mill I have ever used, so I cannot compare it to anything.
              1/8" per turn of the handle.
              The motor appears to be quite a bit better than the typical Chinese motor. The motor and contactors are still going strong.
              I have replaced the lamp, the hinges on the pulley cover, the v-belts, and the rubber chip guard. Did some minor wiring repairs, can't remember what they were.
              There was some slop in the quill at full travel. I added a couple of brass-padded setscrews to fix that.
              As it comes from the factory, the bearing preload on the lead screws is not adjusted properly and gives the impression of having a lot of backlash. There is a takeup nut, find it, throw some lube on the bearings while you are at it, and snug up the preload. That's standard procedure for any HF machine tool.
              It is not a full size machine, but it is not a piece of junk, either. It is a real mill, worth considering.
                1/8" turn per handle? How in the world do you get anything done? I couldn't do it... I'm so used to .2 per rotation that I'd be way the heck off everytime I tried to move the table.
                I'm so used to counting ".2, .4, .6" etc in my head each time I see the ball whir around that it'd probably take me a couple of months to un-learn the habit!
                I looked at one of those mills too but decided that, since I already have a 3-in-1 and I now have room for larger machines, that I'd rather wait and look for a much larger used machine. It didn't seem too bad though - in fact I would put it up slightly higher in fit and finish than the other machines they had on the floor, but that may just be chance.
                  I have the Enco clone of this machine got it about ten years ago, then awhile back added a DRO and have been very satisfied with it. It is big enough so you can make some decent sized parts on it but not so big you can’t get it into the basement.
                  It disassembles easily so it can be brought in in-pieces.
                    I am in the same camp as RobbieKnobbie here. I started out looking for the Harbor Freight 6X26, but none of the local stores had any and couldn't order one due to it's back order status. Also tried the nearest Grizzly outlet to me - again, none in stock and back ordered. So I started looking for something similar at Enco's web site and ran across the same 8X36 that RobbieKnobbie has. Long story, short.... I bought it and haven't looked back since either.
                    Turns out that I got my Enco mill for the same amount I would have paid for the Grizzly 6X26. My basement is very small and also accessed by stairs, and I was able to disassemble mill outside and bring in parts one at a time, and re-assemble inside.
                      Choices
                      Thanks for the many replies. I suspected that the lead screws are metric, and it sounds like they are on the HF machine. That wouldn't do for me.
                      MickeyD suggests the RF-45 or clone like enco:
                      http://www.use-enco.com/CGI/INPDFF?PMPAGE=531&PMCTLG=00
                      Which do you guys think is better in terms of rigidity and accuracy? The 6x26 or the RF-45?
                      A bigger machine is just out of the question.
                        You could always put a DRO on it, and then you wouldn't care about the metric lead screws.... Once you have a DRO, you'll never want to go back to reading the lead screw dials again
                        Corm
                          1/8" per turn is metric ???
                          Dunno about the diameter of the lead screws, if that is what you mean.
                            I have the Jet model JVM-626 version of this mill. Bought it new in 1986. I use it to make parts for my product line. Most of these parts are very small so I use dial indicators and rarely use the dials on the machine. The lead screws are 8 TPI so that's .125" per revolution. I have no complaints about the machine and it's served me well for many years.
                              The PDF manual on the HF web site says that the lead screw is 1"-8 thd.
                              And, if it were me, I would prefer the 6x36 over the RF-45 machine just because it's a knee machine (if I did my homework correctly).
                              "Those who hammer their guns into plows will plow for those who do not."~ Thomas Jefferson
