powerfeed problem
  • powerfeed problem
    Please share experience with the inexpensive powerfeeds from China? My electronics that adjust table speed seems to be going out. When you try to adjust the speed it seems to jump to rapid traverse? Any ideas as to a fix?
    On mine the pot that adjusts the speed went bad. I replaced it with one that takes more turns for full range. Then a resister burned out and it two was replaced. Been running fine ever since.
    Good luck,
    John R
      I put one on all 3 of my Bridgeports axis. Haven't had any problems. Servo has a website with good instructions, instead of the chinglish one's that come with the feeds.
