6 inch aluminum oxide grinding wheel...
  • 6 inch aluminum oxide grinding wheel...
    ... does anybody make one in a type 50 wheel (metal plate backing)?
    Well, somebody does (or did!).....
    I've got a nice one on my Delta, so my buddy says "where'd you get that good lookin AO wheel" and I says " oh, I got that from -----" and went totally blank...have gone through every catalog I can find and racked my gray cells and cannot pull it out!
    I really thought it had come from Victor, but if it did they dont show it anymore....
      Is this what you want?
      http://www1.mscdirect.com/CGI/GSDRVS...00000072576233
      "Those who hammer their guns into plows will plow for those who do not."~ Thomas Jefferson
        Link does not work for me - just comes up with an empty search page.
        Do you have a part number? Thanks.
          You know what........? After looking again, (part: MSC #: 90852377) it might not be right. It says type 5, 4" wide The catalog (page 867) says 1" wide. I've been half-fast looking for one myself.
          I will call MSC later..........
            No Direct Link but: http://www.kbctools.com/usa/main.cfm
            Search on P/N 1-704-368
            The online catalog (page 536) shows $21.55 but the site shows $27.55 which seems pretty high. You could call them.
            I bought one years ago for the HF carbide grinder from KBC but I don't know if it was this one. The OD was slightly too big for the HF. I just hit the wheel with a diamond point. Others enlarged the clearance in the grinder.
              You know what......? You pointed me to exactly what I was looking for!
              It looks like # 99607152 will fit my needs very well. Oddly enough, I searched Norton's web site for an hour and never did see such a wheel listed there. And somehow I missed it completely on MSC's site. So THANK YOU very much!!!
              I've been trying to figure out a way to do both HSS and carbide on the same carbide grinder - and just too blind to be able find the AO wheel.
                I'm not sure that we are getting the straight scoop from that page, when I checked the Norton site, that part is a straight hole not a plate mounted. I'm going over to MSC later, I'll check with them to get confirmation.
                  Keep looking guys. They're out there. I had a vertical spindle surface grinder that a previous owner had converted to use that type wheel.
                  I was always able to buy them from the online tool houses.
                  BTW, in the rare instance an odd ball size grinding wheel is nowhere to be found, you can have them custom made at a surprisingly reasonable price. Pacific Grinding Wheel (or something like that) north of Seattle made wheels for me in the past.
                    My wife sells those wheels as a special order item, readily available. Don't know price or delivery time though, She's out for lunch right now.
                      Well............ The counter help at MSC was not worth the trip, and the guy at Grainger looked at me like I was out of my mind. He said he didn't know what I was talking about... the moron...
                      It looks like ( http://www.kbctools.com/usa/main.cfm , P/N 1-704-368) this KBC part might be right so I ordered one, I'll check back when I get it.
                        I recently purchased the Harbor Freight grinder for carbide and have been looking for an al-ox wheel to put on it for HSS bits. Looked everywhere I could think of MSC, McMaster, internet, etc. and just gave up!
                        Looks like this may work. Do you want it for HSS or something else. Let us know if it works.
                        Thanks for the link,
                        Reggie
                          The one suggested from KBC above (1-704-368) works and I have seen it recommended on several BBS. Also check out J&L item number 90852377 which is listed as a type 5. The only catch is it has a 1" center hole. If everyting else matches, it should not be too hard to expand that to 1.25"; but it is a better looking wheeel and hardness of I instead of K for theone from KBC . DavidH
                          DH
                            Thanks - I appreciate that....
                            p.s.
                            Could you let us know the max RPM for this wheel also when you get it?
                              ...Could you let us know the max RPM for this wheel .....
                              Well, it finally got here..... (5 days in shipping, I don't know what that is all about)....
                              It looks to be correct, dimensionally. I'll install it tonight and let you know. It is a 45 grit with a 3450 max. rpm so, it should be great for roughing..
