I have a spare alternator I'm rebuilding with new bearings .
The front bearing near the pulley is a conventional tap home type ...fine
the rear ...a little bit smaller ...has a corrugated piece of tin around its circumference to make it fit in the recess.
why is this ...
1. did they not have the right external diameter of bearing to fit in the hole ?
2. is it there to give the bearing leeway ?
3. or another reason ..
should i buy a bearing the same size as the hole without the corrugated tin
or should i buy the same bearing again .
the alternators on this car...rover 420 , are short lived ........has massive serpentine Polly-v drive belt that drives... water pump ..steering pump..alternator.........and has a spring loaded tensioner ......im not joking ...has more than 50lbs pressure on the belt from the tensioner.
The bearing on the tensioner pulley has gone also ...all in less than 80,000 miles....which is normal for these cars.
foot note
im replacing both bearings allthough only the rear is trashed ...
All the best.....markj
why is this ...
foot note
