Hi
One of the schools lathes has a limited flow of coolant. I pulled out the tank and pump to clean/check etc.
The pump is a submersible type, powered by a small 3ph motor.
There was nothing obvious and virtually no crud anywhere. I cleaned out the line from the pump to the outlet, minimal blockage there. The impeller looks good as does the pump housing. The inside of the diecast pump housing does have some mimimal pitting/corrosion.
After this clean and check, I fitted the pump in the tank and ran the pump (under 4" depth of coolant) through its short length of hose back into the tank and watched the flow. Everything looked good with a good flow of coolant.
I let this run for about three minutes and checked again. The flow was about half the starting flow. The longer I left it running the more the flow decreased until it reached a substantialliy diminished rate.
Any ideas why?
Could the coolant be "airated" and these bubbles affect the flow? Something like a cavitating prop? The coolant being used is a water soluble oil based coolant.
The coolant tank was only half full during the test/check, maybe it would work better if the tank was full?
Thank you...
Any ideas why?
Thank you...
