Please help...does this look good for a noob?
  • Please help...does this look good for a noob?
    winnipeg.kijiji.ca/c-buy-and-sell-tools-equipment-WTS-vertical-milling-machine-220-volt-type-fm-vo-b-W0QQAdIdZ87513690
    What questions should I ask? Is this a decent mill for the price? It's close to me and in my price range. I don't intend to use it daily, but I want something decent to get my feet wet. Many thanks in advance for all the knowledgable input here!
    OK, clearly I am incapable of posting a proper link. If you google kijiji for Winnipeg, I'm hoping someone will look at this mill and help me out. Thanks.
      WTS vertical milling machine, 220 volt, type fm - vo - b ...
      Location: Winnipeg Date Listed: 13-Nov-08. this is a vertical milling machine, its in good condition. i have purchased a larger unit and have no more need ...
      Nope.
        http://winnipeg.kijiji.ca/c-buy-and-...QAdIdZ87513690
        It appears to be a clone of the Clausing milling machine similar to this one from Grizzly;
        http://www.grizzly.com/products/Wood...lworking/G9959
        It is about half the cost of new, and if in reasonably good condition, it is not a bad buy. The easiest way to check it out is to try it under power and see how it works.
        Jim H.
          Thanks for helping with the link, and thanks for the opinion and description. I'm gonna look at it tomorrow night. Kinda tough, cause I know so little....I'm a diesel and auto mechanic, not a machinist...but I sure like to learn new things!
            Yes, that is indeed a clone of the Clausing, generally referred to as the "6x26". Its a dandy little mill for a beginner,with getting the benefit of a knee a real plus,
            That price is not especially a bargain as its close to the cost of new-
            http://www.wttool.com/product-exec/p...ine_WT_Import_
            If he should have a nice collection of goodies to go with it, it would help tremendously, but with him having only gone to a larger mill, I'd bet he will have the bare minimums with it. And with you just starting out, you'll need almost the cost of the mill to 'outfit' it -- its pretty useless without the tools.
            You might visit over at the yahoo group dedicated to this mill --
            http://groups.yahoo.com/group/6x26millingmachines/
              Guys...he's from Canada eh! I'm bettin that mill is under half price of new.
                LOL.......as soon as you cross the border double the price of everything. That said it appears to be a small good stout manual machine, likely excellent for the beginner, if it checks out OK I'd go for it.........if he's gone to a bigger machine and the spindle is different get as much tooling as he has, or use it as leverage for bargaining, start at 1K or 1200.......
                Opportunity knocks once, temptation leans on the doorbell.....
                  Thanks to all....I'll look and report. Yes, I'd like to get some tooling with it if possible.
                    Hi. The 6x26 and 8x30 mills look similar from the column up but they have different base stands.
                    This one appears to be the larger machine as it has the cast iron base cabinet. I have a KBC VM-22 which is the same as the one you are looking at (going to). The one big advantage of this machine other than the slightly larger table is that it has about 20" of clearance between spindle and table vs 12" for the 6x26 machine. Busy Bee also sells this machine (B048)
                    Put it this way, I am very happy with my machine - got it into the basement after taking it apart and it does the job for me.
                    Good luck.
                    Geoff
                      Ammocoman has a very good point here --- if it is indeed the machine he is describing then the price becomes MUCH more attractive. If memory serves me, the specs,- aside from those Geoff gave- on the table are 8x30.
                        Yes, I called him and the table is 8" by 30"!! Thanks, folks...I'm very happy for the help. I'll probably buy it if it ain't sold!
                          Assuming it hasn't been flogged, it should be a good machine for a home shop.
                          Price seems reasonable to me, especially if you can get some tooling with it. Since the seller has just bought another mill, however, he'll probably keep the tooling. I wouldn't let that be a deal-breaker though.
                            Well, I bought it. Paid his price, but he did throw in a few end mills. Now the search for more tooling begins. BTW, this machine is stamped with the make "Friendly Machine Corporation". It is made in Taiwan. Seems to be reasonably well made and heavy. Any input on that? I googled it with nothing turning up.
                              Congratulations!!! You will love it. A mill opens up a whole new world. I have a vertical mill that is pretty old and noisey but it beats nothin! Great acquisition. Becareful moving it they are top heavy. We had three guys and rolled it on cast iron pipe into the back of a pickup truck tilted it in and unloaded the same way. Thank God no steps. Good Luck! Fred
