Need Help finding belt for a Tree Mill 2UVR
  • Need Help finding belt for a Tree Mill 2UVR
    Can any one help with a source for the belts inside the mill head that are in the oil case for the power down feed? There is two of them and they are Gilmer timing belts, and must be able to be around oil splash.
    Dan
    OOOOOH!Though one,timing belts for oily conditions can be tough,I'll take a look around for you if you can find me a belt number or give me the specs-i.e. outside length, width and tooth count.
      Wierdscience,
      The belt is 12mm wide and about 140mm long( double if you cut it and layed it out) there is 47 teeth, which are on 6 mm centers. If you could help locate one I would be very thankful.
      Dan
        I have a 2UVR. According to the parts list there are 4 belts. They are:
        1. 9350 x 1 x S2B4 Timing Belt
        2. 9246 x 1/2 x S3B4 Timing Belt
        3. 1150 Truflex Belt(for the varidrive)
        4. 20 FS Reeves Belt(There is a second
        number that I think supercedes the 20FS.
        It is FS20317)
        No.4 is the little V-belt under the head for changing the feed rate.
        Tree Tool & Die Works is in Racine,WI
        The last phone no. I have is: 414-637-7693
        Hope this helps.
        Lee
          As luck would have it I got an email from a guy that purchased some about six month ago and he sent me their phone #.
          Ask for Colin at 414-423-3000 He has them in stock and I should have them all in a week.
          I think I will order an extra one of each to have as a spare. Thanks Again for your Help.
          Dan
            Yes get extras,47 teeth is not a over the counter stock belt,probibly proprietary.
