replacing guide ball bearing on 14" bandsaw, need anything special?
  • replacing guide ball bearing on 14" bandsaw, need anything special?
    I was going to order a plain vanilla shielded bearing from McMaster for replacing the blade guide rear bearings in my Delta 14", but wondered if maybe the plain old bearing that was in there wasn't right to begin with when I bought it at auction.
    There's sites selling bearing specifically for this for 3x the price, but I assumed that's the sucker price, not a different product. Any problems with this item for the job?
    Part Number: 5972K326
    $4.00 Each
    Type
    Ball Bearings
    Ball Bearing Style
    Double Shielded
    Ball Bearing Type
    General Purpose
    System of Measurement
    Metric
    For Shaft Diameter
    10 mm
    Outside Diameter
    30 mm
    Width
    9 mm
    ABEC Precision Bearing Rating
    ABEC-1
    ABEC-1 Precision Rating
    Regular
    Bearing Trade Number
    6200
    Dynamic Radial Load Capacity, lbs.
    1,340
    Dynamic Radial Load Capacity Range, lbs.
    1,001 to 1,500 lbs.
    Maximum rpm
    24,000
    Maximum rpm Range
    15,001 to 30,000
    Temperature Range
    -4° to +248° F
    Bearing Material
    Steel
    Shield Material
    Steel
    Specifications Met
    Not Rated
    Note
    Grease lubricated.
    No need to spend a lot of time researching these gellfex, plain is fine.
    Have replaced them on cheap and quality saws, plain old shielded bearings.
    Ken
      Get a pair
      Get a pair and replace the upper and lower bearing. Take the "best" of the old bearings and wire it to the saw as a spare when one of the new ones gives up many years down the road. While you are taking things apart make sure to clean and adjust the complete guide system. I remove the table for this operation. My preference are Rock Maple guide blocks and stoning the back of a new blade when installing it. I make a stick of block material with the table saw and cut a pile of them ready for use.
