Cutter I can't remember
  • Cutter I can't remember
    There is a type of endmill that is used to make "shoulders" or bosses. It's basically a plunge cutting mill with the middle removed. Think of a small holesaw with a very thick wall.
    Anyone know what it's called? I may have use for one.
    depending on size i might use an annular cutter from a mag drill set up
      Hollow mill?
      Russ
      Master Floor Sweeper
        That's it. Thanks :-)
        Originally posted by BadDog
        Hollow mill?
          Hollow or Shell mill.
