I've decided to use the mill more for repetitive small fastener holes, rather than laying out, center punching, pilot drilling, then main drilling.
So I put a stop on the mill vise jaw, and use an edgefinder to locate the back jaw and the stop, then set the XY for my hole and drill it in delrin using a screw machine length #30. It's off by 3 or 4 thou in both axes. I then layout the hole on the work, prick it, and use the sharp ended edge finder to double check my location, it's dead on. I switch to a 5/16 center drill, figuring maybe the stubby drill is wandering, and still get the error.
The drill is in a 3/8 Jacobs with a 1/2 straight shank in an ER32 collet chuck. I have about a .001 runout at 1" from the Jacobs, but even that should just give me an oversized hole, at least with the center drill. (question:actual runout is half the measured variation on the indicator, right?)
So any ideas on where I'm going wrong? On these pieces it's not critical, but I'd sure like to get my methodology right, rather than having to zero in by trial and error.
