What is the cutter made from?
Tuning machine gear material
Nice Job!
You mentioned the following and I'm rather curious which way you went. Guessing you made the cutter on the mill since it is a square tooth, but how did you end up doing it.
I'd think chasing the spiral on the worm is necessary similar to gashing a gear would be, this correct?
Thanks,
- Reed
Raleigh, NC
I plan on making it as original as possible. I had thought of the rotating toolpost geared to the spindle idea as a last resort, but I have another idea that is practically identical to your second suggestion. Instead of cutting a straight worm and using that to make the cutter, I am thinking of making the cutter on the mill using a dividing head and a single point fly cutter ground to the proper geometry, adding some clearance angles, then hardening and sharpening. I do like your idea of cutting a straight worm first and using that as a "cutter to make a cutter", though.
Originally posted by 3jawA2 tool steel.
Originally posted by TinkererDid you cut a straight worm drive and feed the cutter into it to get the curve?
The cutter teeth were made on a vertical mill with a right angle angle attachment and a "spin-dex" fixture set at the helix angle of the worm. This is also the same setup used to cut the gears. I made a fly cutter to hold the cutting tool. The cutting tool was held at the correct angle in a grinding vise with an angle block that I had to make and then mounted the vise on a sine plate and ground on a surface grinder. I had to make the angle block and use the grinding vise since I don't have a compound sine plate.
The whole thing was a leap of faith since I wasn't sure my idea would work but, to my relief, it did work just like I had planned.
I don't think I'll take on any more challenges for a little while!!!Last edited by 3jaw; 03-16-2009, 09:53 AM."The truth is incontrovertible, malice may attack it, ignorance may deride it, but in the end; there it is." Winston Churchill
