"Real" computer requirements for running Mach 3??
  • "Real" computer requirements for running Mach 3??
    Hey guys...
    I'm still creeping along...as snow clearing/wood chopping duties allow...trying to round up the stuff I need for the gurl to start learning some cnc stuff.
    Replacing the driver from Xylotec isn't going to happen...he doesn't sell the single driver anymore and won't even repair the old ones (hmmmm???)
    He referred me to Geko..ok.
    I've decided to go with Mach 3 instead of my old turbocnc setup.
    I figured I'd just buy a used Windows XP computer out of the paper and be ok.
    However...I've been reading the odd snip here and there.
    Seems there is a lot more to it than that. Seems like I could easily buy a machine that wouldn't work.
    Any suggestions what I should buy(or try to find)? As in used?
    Thanks!
    Russ
    Russ,
    We [ small son and myself ] have probably supplied about 40 to 50 Mach boxes over the last two years as a lot of the machines have gone out turnkey.
    We have also had to babysit owners who have supplied their own boxes.
    Initially we were buying new boxes from a UK internet supplier for £110 each, just the box and with Linux installed, took linux for, installed a copy of XP home and away.
    Problem now is these linux machines don't have a parallel port so we have to fit an extra card and some don't work with Mach.
    Recently we have been buying up S/H boxes off Ebay.
    I know it's different here for us compared to you given distances but I search with 25 miles of our post code and only bid £40.
    We still get plenty and it means we can collect, saving postage and call in a pub and get a meal out.
    Most of these boxes have XP already installed so that one licence less.
    So far we have had three boxes that won't work, two we bought that are borderline at 1.2 Gig and one Dell from a customer that can't see the 11Kh charge pump signal at any price but this one is real weird, small mother board and everything plugs into a daughter board and it's mega heavy.
    Specs we recommend.
    The specifcations that you need for a computer to run mach3
    • Minimum Spec.
      • 1.2GHz CPU
      • 512MB Memory
      • 20 GB Hard Drive
      • Windows 2000 or XP (will not work on vista correctly)
      • 1024 x 768 Monitor for standard screen sets
      • Parallel port (Printer)*
    • Recommended spec
      • 2GHz CPU (Multi-Core CPU's will run with Mach)
      • 1GB Memory
      • 20 GB Hard Drive
      • Windows XP
      • 32 MB AGP/IDE-E Video Card
      I tend to look for used Dell machines for anything like this. I have a coule of GX270's which do everything I want and cost about £60. The best thing is if you use a Dell XP install disk it auto-generates a key which is usable for activation and auto-updates.
      Monarch 10EE 1942
        I'll add that if you are buying a used machine make sure it includes some way to reinstall Windows. Then get some help and wipe it clean and do a clean installation of XP with all the bells and eye candy turned off.
        If you buy a new machine you should turn off all the unnessary crap too. HP is especially bad in that respect and I would avoid an HP box.
          I have been using mach on my bridgeport cnc conversion that I did last winter. I started with my old desktop machine, a 1.2ghz 512K amd processor. It worked fine, no complaints.
          Then a friend gave me a hp laptop, 1.8 ghz with a parallel port. Also laptops are not recommeded due to the power saving features raising hell with mach, I had to give it a try. I disabled the power saving features quite easily. The pulse stream looked even better than the desktop machine using machs test program. I now have the laptop running the mill and absolutely love it, all those cables for the keyboard/mouse etc GONE. A nice small package, all self contained. Again, laptops are not recommded, many (most?) will not work with mach, but some will. I had nothing to loose by trying but otherwise I would get a known compatible laptop.
          Lastly, the speed and power of the machine required has a lot to do with how complex the gcode you are going to run is along with the speed of the controlled machine. A fast mill executing rapid short moves demands a lot more of the computer than a slower homebrew conversion doing simple short gcode programs.
            Tork. I'm using an old Dell 1GZ, 20 mg HD, Windows XP pro, parallel port,and it runs just fine for both mach3 and lazycam. If you want mach3 to run faster, get a faster machine.
            I would advise staying away fropm those old Dell opti-whatevers. I've owned four from three different sources and they all went TU in less than a year of casual use.
            Check out Tiger Direct, or Fry Electronics for a cheap refurbished or new computer.
            CNC Zone can answer a lot of your other questions
              OK wiseguy, whos laptop was it?
                I actually had better luck running 2K Pro than XP. One thing that also helps is to not install networking. Windows has a nasty habit of trying to phone home at 2:00 in the morning and crashing any jobs that you happen to have running then. Also by leaving it off of the network, you can leave the AV and spyware programs off which cause a lot of timing issues on their own.
                  Stripping the eye candy off??
                  Sounds simple right? A little too vague? well Mach3 has scripts to tell you what you need to delete..
                  I'm loving this new emc2.. free. I downloaded some wizards that are not as pretty as mach3's but work. Also free. Built as a package it downloads onto the hard drive what it needs to work.
                  With Mach3.. the wizards are worth the price of admission.. you just load the variables into the idiot box, it does the thinking for you, push the button, it dumps the gcode into the cnc program.. push run.. mission accomplished.
                  My wife has heard the singing of the lil steppers here on the coffee table for a week now.(she is tired of it). I keep wanting to add bells and whistles to it, but it is ready to bolt onto the southbend shaper..
                  Snow is a good excuse to play inside, does most the guys up there have two dozen kids? perhaps they don't have home machinist hobbies?
                  Excuse me, I farted.
                    What Evan said, but be careful with the Dell machines -- they ship with a weird version of Windows XP that's locked to that particular machine, by an encrypted value in the BIOS.
                    I got a Dell machine with Windows XP Home awhile back, and wanted to install XP Pro on that machine, and use the Dell XP Home disc on an older Dell machine, and it wouldn't activate.
                    I called Dell, and they confirmed that they lock the XP disk to the machine it ships with...
                      If you use a Dell XP pro install disk it doesn't even prompt for a key. As I said updates fine, activation no problem.
                      Monarch 10EE 1942
                        It doesn't prompt for a key because the key is embedded in the BIOS.
                        Are you activating it on a different machine? My Dell XP disk, from a Dimension 8200, will not activate on any machine except the one it was shipped with.
                        I can send you the disk if you want -- it's useless
                          I got a stack of corporate XP pro discs and windows sheaves/install numbers.. I thought it was manna from heaven..
                          Won't install on anything. Just like Lazlo said..
                          Crap, junk, more junk, ticked off hillbilly.. sneaky son of a guns...
                          I got a tubing bending program from 2020 software solutions.. won't reinstall on anything without a confirmation number from the author.. now that was six or seven computer crashes ago and I gotta call up and beg another install number.
                          I sure hope I didn't give him the idea.. I was telling him about reading the bios serial number on tufting machines I wrote software for in the 80s.. sneaky corporate spies had my software in two hours of machine's introduction.. Think all the spies work for the government, nope.. cousins and brother in laws..
                          Ding dang it.. save stuff only to learn it's a pile of pig poo... I had a buddy nicknamed squirrel.. he got gave by me a indian arrowhead.. he beamed, glowed.. was so excited.. over his house there is a pathway from the front door to the bed, a small alcove where the tele sits... boxes to the ceiling.. somewhere in one of them boxes is a arrowhead. Packrat, just like a squirrel.. so today I am trashcanning the special XP pro discs before I need some more boxes to store pig poo in...
                            Yeah. If the power stays on. We have this morning for the first time I can recall an official BLIZZARD WARNING. Up to a foot of snow, -10 degrees and winds up to 60mph. I'm going to warm up the genset.
                              I've successfully run a simple Mach3 program on a 400 Hz machine with Windows 2000, but I suspect that is pretty marginal and not to be recommended.
                              There are now 3rd-party alternatives to the parallel port, the SmoothStepper interface board being one.
