Putting a flat on a endmil
  • Putting a flat on a endmil
    Questions,
    1. How do you put a "nice looking uniform" flat on a carbide endmill?
    2. And Silver & Deming Black Oxide general purpose drill bits?
    ... if you say grind, then what sort of grinder, fixture or method ... wheel etc.?
    Regards,
    -SD:
    Carbide: Diamond wheel on a surface grinder.
    HSS: AlO wheel on a surface grinder. Or CBN.
      If it's only for a set screw, just hit it with a bench grinder. :-)
      ...lew...
