How to mount a mist nozzle?
  • How to mount a mist nozzle?
    New Year Resolution –Clean the shop-Finish some projects
    Cleaning the shop part is going satisfactorily. Not fast but moving in the right direction. One project that is 90% complete has me mentally locked up. I have built a mister to go on the mill. I can’t decide how to mount and hold the nozzle. It needs to be easy to take on and off and to point accurately. Any help/suggestions would be appreciated.
    Byron Boucher
    Burnet, TX
    How about a magnetic base?
      Both snap flow and loc line are a series of fittings that lock together including an end nossle --- you just move it off to the side when not in use, the body of the mister unit usually mounts off to the left side of the mill head but it sounds like youv already built yours -- thats where my "typhoon" mister mounts and its really never in the way of anything, its a flat plate with three screw holes and mounts directly to the quill hub opposite handle side, both snap flow fittings and loc line just fold up and out of the way when not in use.
