tool bit angles
  • tool bit angles
    I had a chart that showed all the rake, relief angles etc. for HSS tool bits for different materials like steel, AL, brass etc. I can't find it at the present, does anyone have a similar chart they can post.
    Thanks.
    Ok, I found one.
      This does not answer the question that you asked. I start with and use 7° on everything. About the only corrections that I make along the way are for boring bar applications and some brass cuttig tools.
      Byron Boucher
      Burnet, TX
        Originally posted by loose nut
        Ok, I found one.
        Would you consider sharing?
        Rex
          It's in a protected PDF file (no printing or coping) so I'll have to copy it and then I'll post it, it's not very large ,I'm just busy now. Maybe tomorrow.
            Ditto ......
              http://www.littlemachineshop.com/Ref...RakeRelief.php
              mel
              Oregon Coast
