BBC cylinder head machining
  • BBC cylinder head machining
    Is there a source for valve guide locations/angles and rocker arm stud locations for BBC symmetrical port heads? Also, can a head gasket be used as a guide for head bolt locations? I have an old set of raw castings and was wondering how to locate the valves/rocker studs correctly. Thanks, emj
